clear screen
clear screen
Description
This command clears the screen of a login session with the termcaps-defined capability and returns the prompt to the top.
Syntax Description
Default
N/A.
Usage Guidelines
None.
This command was first available in ExtremeXOS 16.1.
Platform Availability
